Question Upgrade Error
- Thermophile
I followed instructions by:
Backing up my live site
Uninstall Kunena 1.5.12
Install Kunena 1.6
After it does that, it seems to install fine. It goes to the "Select an Installation or Upgrade Option" page. With "Reinstall Kunena 1.6.0 build 3620." "Migrate database and files from Kunena 1.5.12." and "Restore from a backup of Kunena 1.5.12."
I choose the "Reinstall Kunena 1.6.0 build 3620" and everything seems fine. But when I visit my homepage I get "Catchable fatal error: Object of class CKunenaConfig could not be converted to string in /home/site/public_html/components/com_kunena/lib/kunena.link.class.php on line 133"
I can still visit the forums by going to the menu link. www.site.com/forums
Just the index will not work! Please help!
You are using plugins/modules which are made for old kunena versions and it's doesn't work with kunena 1.6.0...
www.kunena.com/forum/172-k-16-installati...kunena-16-check-list
Most likely you have installed Kunena 1.5 plugin or module (or maybe SEF?) that doesn't check Kunena version and breaks the page.
- Thermophile
I don't know what it could be. Only thing I was using was uddeIM for Private Messaing, which I uninstalled and changed. It still doesn't work.
When I try to uninstall Kunena 1.6 I get
"Fatal error: Call to undefined method MenusHelper::cleanCache() in /home/site/public_html/administrator/components/com_menus/models/menutype.php on line 276"
Also on my forums page I have
"Kunena Notice: You do not have default Kunena Menu."
Menu issue, see PM and this thread: www.kunena.com/forum/168-k-16-support/63...it=10&start=20#64053
- Thermophile
Matias wrote: Fatal error: forum.joomla.org/viewtopic.php?p=1673054
Hey Matias! That seemed to take care of both of those problems! Thanks tons!
