Question [SOLVED] Installing Kunea 1.6
16 years 2 months ago - 16 years 2 months ago #61897 by agor
Hello, I'm ussing Kunena 1.5.12 few days and now want to upgrade to 1.6.
I tryed to uninstall it from the Joomla install/uninstall under components and try to install newest 1.6 version (com_kunena_v1.6.0-RC2_b3373_2010-08-31).
Meanwhile all the requirements are ok.
Is there special way to update to 1.6, I was unable to find anywhere precise answers how to upgrade or install it fresh one.
Cheers
Last edit: 16 years 2 months ago by fxstein.
16 years 2 months ago #61898 by agor
Replied by agor on topic Re: Installing Kunea 1.6
Ohh I allmost forgot the error message when I installin the newest kunea is:
* JFTP::write: Bad response
* Unable to write entry
every other extension is installing properly dont have any access problem with ftp or such a things.
16 years 2 months ago - 16 years 2 months ago #61899 by Mortti
Replied by Mortti on topic Re: Installing Kunea 1.6
I think moderators move this topic to K 1.6 Installation and Upgrade forum?
Mean while check from your Joomla! backend Help -- System info
* System Info
* PHP Settings
* Configuration File
* Directory Permissions
* PHP Information
Try also after you disable FTP... Site -- Global Configuration -- Server -- FTP Settings -- Enable FTP: No, does it work when you just install that package via Joomla installer.
Last edit: 16 years 2 months ago by Mortti.
16 years 2 months ago #61902 by agor
PHP settings are default I have hosting from justhost.com permision for database is all set to allowed. If you need specific information to solve this please tell me where to find that kind of information so I can post here.
16 years 2 months ago #61903 by Mortti
These are most important now(because you haven't give any other information yet):
so there is not write permission when you try install that RC2 package. (you don't have to unistall that 1.5.12 before)... check permissions and disable that Joomla! FTP feature and try again. Tell also some basic information of your system, you will found those my previous post(at least System Info).
I think also those moderators is hard to guess your problem if you don't give some more information.
16 years 2 months ago #61904 by agor
I disable the ftp settings from global configuration > server and now when I try to install it say:
Warning: file_put_contents(/home/soccer/public_html/tmp/install_4c960ef8cd4d3/) [function.file-put-contents]: failed to open stream: Is a directory in /home/soccer/public_html/libraries/joomla/filesystem/file.php on line 555
Unable to find install package
my system info:
PHP Built on: Linux rs19.justhost.com 2.6.31.9-grsec #1 SMP Wed Apr 14 03:03:22 CDT 2010 x86_64
Database Version: 5.0.91-community
Database Collation: utf8_general_ci
PHP Version: 5.2.13
Web Server: Apache
Web Server to PHP interface: cgi
Joomla! Version: Joomla! 1.5.2 Production/Stable [ Woi ] 22-March-2008 22:00 GMT
User Agent: Mozilla/5.0 (Windows; U; Windows NT 6.1; en-GB; rv:1.9.2.10) Gecko/20100914 Firefox/3.6.10
