Solved [Resolved] Moving and upgrading problems
14 years 6 months ago - 14 years 6 months ago #123979 by coma
Need some help, please!
I have moved Kunena by exporting all *_fb_ tables from the old site to the new site, old version was Kunena 1.5.5
New joomla version is 2.5, Kunena 1.7.2 After installing the kunena component on the new site the installier script correctly detects the old version. I started "Migrate from 1.5.5" a lot of things happen with green "ok" but at the end i get the following error:
Fatal error: Cannot access protected property KunenaModelInstall::$db in /www/htdocs/.../administrator/components/com_kunena/install/upgrade/upgrade-1.6.0_attachments.php on line 18
What I am doing wrong?
Any idea how to solve the problem?
Thank you all,
Ralf
Last edit: 14 years 6 months ago by sozzled. Reason: Change topic icon and subject
14 years 6 months ago #123981 by xillibit
14 years 6 months ago - 14 years 6 months ago #123983 by coma
Replied by coma on topic moving and upgrading problems
I tried that:
Just look here : www.kunena.org/forum/172-K-17-Installati...elInstall-$db#121023
but I don't know where to put it exactly in administrator\components\com_kunena\install\model.php
Insert in field variables:
public $db = null;
Any help?
Last edit: 14 years 6 months ago by coma.
14 years 6 months ago #123985 by xillibit
by example line 55 :
class KunenaModelInstall extends JModel { /** * Flag to indicate model state initialization. * * @var boolean * @since 1.6 */ protected $__state_set = false; protected $_req = false; protected $_versionprefix = false; protected $_installed = array(); protected $_versions = array(); protected $_action = false; protected $_errormsg = null; protected $_versiontablearray = null; protected $_versionarray = null; public $db = null; public $steps = null;
14 years 6 months ago #123990 by coma
great thank you that works fine!!!
Ralf.
