Question Error - Installation stopped. Need which dir to chmod 777.
Thanks,
General information about installing K 1.7.1: read K 1.6 & K 1.7 Installation Guide .
Chmod it to 777 will allow it to write then I will put all them back to 755 when kunena finishes, but this thing will not go thru.
What is wrong??
That's about all I can tell you as far as file/folder permissions are concerned. I don't really know why you're having these difficulties but, if you start with a standard Joomla setup (in the ways we have discussed in this topic) then the Kunena installation should work without problems.
All I need to know is what file directories are affected by Kunena 1.7.x (j1.7.x) installation. There seem to have no information in that documentation anywhere. I can manage to reorganize later and put it in correct file permissions based on Joomla standards. For now, is is even possible to find out which files directories are affected during install so I can manually allow it for now.
I never had any problems on any extensions on j1.7 that I have during installs. Only Kunena is giving me this error and did not finish.
thank you.
/components
/media
/modules
/plugins
/languages
and the same list for administrator.
But if installation seems to stop, the issue is probably buggy browser, which breaks on redirects to the same address.
