- Thank you received: 2
Question Newbie help: Installing K 1.7.1
- irishbiker
- Junior Member
14 years 9 months ago #112777
by irishbiker
Newbie help: Installing K 1.7.1 was created by irishbiker
Hi all
Just need some direction, I'm new to Joomla and Kunena.
Running Fedora 14 and Joomla 1.7 I'm trying to install Kunena but I'm running into the following error:
REQUIREMENTS CHECK: FAILED - Minimum version requirements not satisfied
PHP version: 5.3.8 (Required >= 5.2.3)
MySQL version: 5.5.14 (Required >= 4.1.19)
Joomla version: 1.7.3 (Required >= 1.7.0)
PHP DOM Extension: DOMDocument (Required)
I've installed php-xml but I get the same error. Any help would be great!
Paul
Paul
14 years 9 months ago #112785
by xillibit
Replied by xillibit on topic Re: Newbie help: Installing K 1.7.1
Try to install php53-xml or php53-devel, maybe you have forgot to uncomment the line related to the extnesion in php.ini file
- irishbiker
- Junior Member
14 years 9 months ago #112795
by irishbiker
Replied by irishbiker on topic Re: Newbie help: Installing K 1.7.1
Thanks for the reply. I'll try the files but to confirm, what entry in php.ini do I need to edit?
- irishbiker
- Junior Member
14 years 9 months ago #112902
by irishbiker
I've reviewed php.ini but I cannot see any entry pertaining to DOM. Can someone point me on where I should be looking?
14 years 9 months ago #112918
by xillibit
Somthing like that : extension=dom.so
The following user(s) said Thank You: irishbiker
- irishbiker
- Junior Member
14 years 9 months ago #112955
by irishbiker
That was the missing bit - seems to be up and working now - Thanks a lot for your help
