Question Error after instal
14 years 11 months ago #112757 by semco
Error after instal was created by semco
I have error after install
500 Internal Server Error
Fatal Error was detected!
Fatal Error: Class 'KunenaParser' not found in components/com_kunena/template/default/threads/flat.php on line 96
The error was detected in the Kunena Component.
need help
14 years 11 months ago - 14 years 11 months ago #112759 by sozzled
Replied by sozzled on topic Re: Error after instal
G'day, semco, and welcome to Kunena.
Is it possible for you to post your configuration report (as requested in the posting guide that appears at the top of this page)?
Sounds like you didn't successfully install Kunena, to me.
Last edit: 14 years 11 months ago by sozzled.
The following user(s) said Thank You: semco
14 years 11 months ago - 14 years 11 months ago #112763 by semco
Replied by semco on topic Re: Error after install
I re install my website I got another problem
I've installed joomla 1.7.3
and CB community ,Now when I log in with CB login I have access to forum is OK
When I logout from kunena login ,and try to log in back to kunena using kunena login I got problem I think is login to joomla ,not to CB login
www.artcon.ca/propertysolutions/
14 years 11 months ago #112786 by sozzled
Let's keep to one problem at a time, shall we? Is it possible for you to post your configuration report (as requested in the posting guide that appears at the top of this page)?
14 years 11 months ago #113169 by Matias
Replied by Matias on topic Re: Error after instal
Clean install? Try to uninstall and install again.
14 years 11 months ago #113350 by semco
Thanks I disabled ,works good now
All the best
