Question Trouble upgrading to 1.7.1
14 years 10 months ago #113245 by asajay
I don't understand. I only got the error message when I ran the Kunena portion of the install -after- uploading using the extension manager install. (Please note that Joomla had already been installed and I made no attempts to re-install Joomla or change any file permissions). So you are saying during the install of Kunena, something tells Joomla to write a file to disk and that's what failed?
Is there something during the Kunena "upgrade" path that causes Joomla to write a file to the disk versus it doesn't during an "install?" I ask because after I removed Kunena and did a fresh install (just Kunena, not any other Joomla files) I didn't get the same error.
Perhaps wiping out the old Kunena install, also wiped whatever file had the bad permission?
Still seems weird to me. But it's all working after uninstalling and re-installing Kunena from scratch.
14 years 10 months ago #113297 by Matias
Kunena calls Joomla installer for its system plugin and all the languages.
Maybe some of those files didn't have the right permissions. Uninstalling usually fixes the issue as JFile::delete() is smart enough to change file permissions in case it was write protected. So you're right -- the file with wrong permissions was wiped out during uninstall.
14 years 10 months ago #113304 by asajay
That makes sense. Thank you for taking a more in-depth look.
