Like announced in the release nots of the K6.4 RC4 release, Kunena project has moved to crowdin :
crowdin.com/project/kunena-forum
to manage translations from K6.4 and beyond. The RC4 release is the last version before the stable, so for all translators please update your translations on crowdin.
Transifex is keept for translations from K6.3 and the previous versions of Kunena.
Kunena 6.3.10 Released
The Kunena team has announce the arrival of Kunena 6.3.10[K 6.3.10] in stable which is now available for download as a native Joomla extension for J! 4.4.x/5.0.x/5.1.x/5.2.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 and issues discovered during the last development stages of K 6.3 Note: Please go to the Kunena Dashboard after an upgrade so that the Kunena database tables are also updated.
I just found where the error message was in the code, and the only place was when Joomla failed to write file into the disk. So it was file permission issue in Joomla installer, not in Kunena. I have no idea of what was the file..
I don't understand. I only got the error message when I ran the Kunena portion of the install -after- uploading using the extension manager install. (Please note that Joomla had already been installed and I made no attempts to re-install Joomla or change any file permissions). So you are saying during the install of Kunena, something tells Joomla to write a file to disk and that's what failed?
Is there something during the Kunena "upgrade" path that causes Joomla to write a file to the disk versus it doesn't during an "install?" I ask because after I removed Kunena and did a fresh install (just Kunena, not any other Joomla files) I didn't get the same error.
Perhaps wiping out the old Kunena install, also wiped whatever file had the bad permission?
Still seems weird to me. But it's all working after uninstalling and re-installing Kunena from scratch.
Kunena calls Joomla installer for its system plugin and all the languages.
Maybe some of those files didn't have the right permissions. Uninstalling usually fixes the issue as JFile::delete() is smart enough to change file permissions in case it was write protected. So you're right -- the file with wrong permissions was wiped out during uninstall.
