Kunena 6.2.6 released
Question Failed to upgrade from K164 to K171
12 years 4 months ago - 12 years 4 months ago #1 by shaul_ei
J!1.7.3 (Just upgraded from 1.6.3)
Trying to upgrade K1.64 to 1.71
It is just stuck while upgrading. I managed to upgrade on my local machine but failed on the remote. Probably permission problem. How can I find more details? Is there a log file for the upgrade?
Thank you
Shaul
Last edit: 12 years 4 months ago by Matias.
12 years 4 months ago #2 by Matias
What do you see when you get stuck? Installer has pretty good error messages. There is/was also known issue with Google Chrome in some environments, where installer just gets stuck on reloading the same page.
12 years 4 months ago #3 by shaul_ei
Thank you for the quick reply.
1. Problem was on chrome.
2. Reproduced on Explorer.
3. Blinking after displaying:
Extract Component
Prepare Installation ... OK
Uncompressing com_kunena-admin.zip ... OK
12 years 4 months ago #4 by Matias
Try FireFox.
By blinking you mean reloads the same page again and again?
12 years 4 months ago #5 by shaul_ei
Firefox was fine. Strange.
Now, when I try to configure the forum, I get an error window:
500 Internal Server Error
Fatal Error was detected!
Fatal Error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 109560 bytes) in libraries/joomla/environment/response.php on line 198
The error was detected in the Libraries.
Does it make any sense?
12 years 4 months ago #6 by xillibit
You need to increase your memory limit into the php.ini file, by setting 64 or 128 mb
12 years 4 months ago #7 by Matias
Usually 32-64MB is enough. But even Joomla docs recommend 64MB.
12 years 4 months ago #8 by shaul_ei
The error message complains about 16M. Am I right.
I have 32M, and I don't believe I'll be getting more.
Any idea how to overcome this. It happens only while trying to configure Kunena. Can I edit something manually - meanwhile?
Thank you!
12 years 4 months ago #9 by Matias
Kunena runs just fine with 16M if you have empty Joomla installation with no extra plugins or components that integrate to Kunena. Of course there are a lot of other things that affect into memory usage as well (PHP version, Apache plugins, PHP plugins etc..).
You have 2 options:
1) Buy a VPS (virtual server) that gives you more resources
2) Make your site simpler by removing all Joomla modules and plugins you don't need
The following user(s) said Thank You: shaul_ei
12 years 4 months ago #10 by sozzled
Matias wrote: Kunena runs just fine with 16M if you have empty Joomla installation with no extra plugins or components that integrate to Kunena. Of course there are a lot of other things that affect into memory usage as well (PHP version, Apache plugins, PHP plugins etc..).
You have 2 options:
... and read carefully K 1.6 and K 1.7 Upgrade Guide
Time to create page: 0.406 seconds
