Question Unable to write entry error
15 years 1 month ago #109869 by msargenttrue
When attempting to do a fresh install of Kunena 1.7 on my Joomla 1.5.9 test site ( http://test.ctaspa.org/ ) I get the error message: Unable to write entry
In order to (try to) rule out permissions issues I have set one of the test versions of the site to 777 throughout and this didn't seem to make any difference.
All minimum php requirements have been met on the server.
I am at a loss to what is causing this issue…
If it makes any difference this site is also running the following extensions:
Community Builder 1.2, CB Paid Subscriptions 1.0.3 and CB Mailing
Any help would be greatly appreciated.
15 years 1 month ago #109870 by 810
Replied by 810 on topic Re: Unable to write entry error
hello,
you need :
PHP 5.2.3+ or 5.3.0+
MySQL 5.0.3+ or 5.1.0+ or 5.5.0+
Joomla 1.5.23, 1.6.4+ or 1.7.0+
So please update joomla to 1.5.24
regards 810
15 years 1 month ago #109891 by sozzled
Yes, I agree with 810. Also you should read K 1.6 & K 1.7 Installation Guide and the K 1.7 release notes.
15 years 1 month ago #109926 by Delphi32
Same here when upgrading K1.6RC3 to 1.7. I checked Joomla version (1.5.24), PHP version (5.2.13), MySQL version (5.0.67), file permissions as per the installation guide, but the error does not go away. The installer reports a successful installation (except for this error), according to the K!Config the forum should be online, but when I access the forum I get 'offline for maintenance' message.
Any clues on how to proceed would be greatly appreciated!
15 years 1 month ago - 15 years 1 month ago #109935 by sozzled
G'day, Delphi32, and welcome to Kunena.
In your case the advice is the similar (although not exactly the same): please study carefully the K 1.6 and K 1.7 Upgrade Guide and look carefully at the technical requirements link in that guide.
If you have a "Forum is offline for maintenance" message, either the upgrade was unsuccessful or you just need to put the forum back online again. The configuation setting to put your forum back online is Forum Configuration » General » Basic Settings » Forum Offline = No
If, however, the installation was unsuccessful, turning the forum back online may not be much use to you. You may need to try the upgrade again. See the upgrade guide for further information. I hope this helps.
Last edit: 15 years 1 month ago by sozzled.
15 years 1 month ago #110025 by msargenttrue
Problem Solved. It was the Joomla version that was preventing the install for me. Funny that I misinterpreted version 1.5.24 as 1.5.2.4 when I was comparing it to my 1.5.9.
After Installing Joomla Tools Core and wrestling with the ftp layer and permissions for a bit I was able to successfully upgrade to 1.5.24. After that I tried the Kunena Forum install and it worked right away. Thanks!
