Question Unable to write entry error
- msargenttrue
In order to (try to) rule out permissions issues I have set one of the test versions of the site to 777 throughout and this didn't seem to make any difference.
All minimum php requirements have been met on the server.
I am at a loss to what is causing this issue…
If it makes any difference this site is also running the following extensions:
Community Builder 1.2, CB Paid Subscriptions 1.0.3 and CB Mailing
Any help would be greatly appreciated.
you need :
PHP 5.2.3+ or 5.3.0+
MySQL 5.0.3+ or 5.1.0+ or 5.5.0+
Joomla 1.5.23, 1.6.4+ or 1.7.0+
So please update joomla to 1.5.24
regards 810
Any clues on how to proceed would be greatly appreciated!
In your case the advice is the similar (although not exactly the same): please study carefully the K 1.6 and K 1.7 Upgrade Guide and look carefully at the technical requirements link in that guide.
If you have a "Forum is offline for maintenance" message, either the upgrade was unsuccessful or you just need to put the forum back online again. The configuation setting to put your forum back online is Forum Configuration » General » Basic Settings » Forum Offline = No
If, however, the installation was unsuccessful, turning the forum back online may not be much use to you. You may need to try the upgrade again. See the upgrade guide for further information. I hope this helps.
- msargenttrue
After Installing Joomla Tools Core and wrestling with the ftp layer and permissions for a bit I was able to successfully upgrade to 1.5.24. After that I tried the Kunena Forum install and it worked right away. Thanks!
