Question [Resolved] Upgrading to 1.6.5 "not possible to delete xxx.php"
14 years 11 months ago #109087 by WCMCC
Joomla Ver: 1.5.23
PHP 5.2.11
re: recent request to upgrade Kunena to 1.6.5 from 1.5.4
when trying to upload & Install I get the following:
"It was not possible to copy the selected file.
JInstaller::install: Failed to copy file: /home/xxxxx/public_html/tmp/install_4e99854bb5e80/api.php to /home/xxxxx/public_html/administrator/components/com_kunena/api.php
It was not possible to delete the selected file.: 'COPYRIGHT.php'
It was not possible to delete the selected file.: 'CHANGELOG.php'
It was not possible to delete the selected file.: 'router.php'
It was not possible to delete the selected file.: 'kunena.php'
found the files in the C-panel all set to 0777
Can't remove them "permission denied"
(No idea what FTP is, if that's going to be relevant)
Any direction greatly apprecited. Many thanks.
14 years 11 months ago #109140 by Matias
Try to uninstall and install again. That usually fixes permission issues like this (all distribution files get deleted).
14 years 11 months ago #109181 by WCMCC
Un-installed 1.5.4
Any attempts to install 1.6.5 or even 1.7 Fail with:
JFTP::store: Bad response
JInstaller::install: Failed to copy file: /home/xxxxx/public_html/tmp/install_4e9b5c2d0b464/api.php to /home/xxxxx/public_html/administrator/components/com_kunena/api.php
JFTP::delete: Bad response
Restored site to earlier date: No change
Forum is practically empty, no issues with re-starting from scratch (Linked with Community builder)
Have contact with Web Site initiator, but priority is way down the list ... may be better to wait ?
14 years 11 months ago #109183 by 810
14 years 11 months ago #109186 by WCMCC
JFolder::create: Infinite loop detected
Unable to create destination
further down...
Warning: strpos() [function.strpos]: Offset not contained in string in /home/xxxxx/public_html/libraries/joomla/filesystem/archive/zip.php on line 325
Sorry ... feeling stupid now :(
14 years 11 months ago #109188 by 810
please check dir permissions:
backend-help-system info- Directory Permissions
check that all maps are green (Writable)
regards 810
Time to create page: 0.286 seconds
