Important problem installing from 1.6.5 to 1.7
Uploaded with ImageShack.us
Now even if you did not install anything the problem and that if I put my site offline in FireBoard 1.5.6 no longer gives me this error:"
how do I do with 'The update?? My System - Upgrade Mootools Mootools version 1.2.4 and Joomla 1.5, so it's good?Errore del server
Si è verificato un errore nel sito web durante il recupero di www.noiceliaci.it/ . Potrebbe non essere disponibile per manutenzione o essere configurato in modo errato.
Ecco qualche suggerimento:
Ricarica questa pagina web più tardi.
Errore HTTP 500 (Internal Server Error): Si è verificata una condizione imprevista durante il tentativo del server di soddisfare la richiesta.
Aspect of your response
You have issue permissions on your sytem, you need to fix that and then re-try to install kunena.
dontorus wrote: Uploaded with ImageShack.us
Now even if you did not install anything the problem and that if I put my site offline in [strike]FireBoard[/strike] Kunena 1.5.6 no longer gives me this error:e
I have the folder permissions problems?? In practice should enable the system folder or pemessi Kunena Do not Understand What should I do exactlyxillibit wrote: Hello,
Now even if you did not install anything the problem and that if I put my site offline in [strike]kunena[/strike] Kunena 1.5.6 no longer gives me this error:e
if you want to see in person go to my site
the site as you understand it in Italian is my mother tongue I just hope I'm writing the text was translated properly.
aspect of your news
