Important Blank Page & Menu Disappear
15 years 3 months ago #104757 by Wiz
I make a fresh installation of joomla 1.7. I install Kunena 1.6.5 but only a blank page came out...so i hit the backpage button, refresh the page, and repeat the same step...still blank page...I repeat the same step again and I notice that 1 components menu disappear each time i repeat the step :ohmy: ...see my attach file... :pinch:
Joomla 1.7
Kunena 1.6.5 B)
Kunena always the best!
15 years 3 months ago #104762 by sozzled
15 years 3 months ago #104765 by Wiz
Replied by Wiz on topic Re: Blank Page & Menu Disappear
no different...i've try it...still the same...and i still don't know why the menu for component is disappear...and i don't know how to get it back... :pinch:
15 years 3 months ago - 15 years 3 months ago #104769 by sozzled
Your image shows that you were trying to install by one of the first two installation options (either the Upload Package File method or the Install From Directory method). The K 1.6 Installation Guide recommends that you use the third method.
How truly "fresh" is your J! 1.7 site? Do you mean that the only things you've installed are J! 1.7 and K 1.6.5 and nothing else? I'm still trying to understand what you mean by "only a blank page came out". Enable Joomla debug mode to see if there is more information than just a "blank page". That's what I would do if I was in your current situation. If this was just a "fresh" installation of J! 1.7 - and Kunena didn't work - then I would start again. Read the K 1.6 Technical Requirements , make sure that my hosting platform met those requirements, and start the whole site construction process again. In less than one hour you can install J! 1.7, Akeeba Backup, K 1.6.5 and your forum should be immediately ready to use.
Last edit: 15 years 3 months ago by sozzled.
15 years 3 months ago #104775 by Wiz
Ok...i've try few fresh installation...it's not a problem with kunena i guess...the one with the problem is an installation from a quickstart file from gavick template. :pinch: :silly:
15 years 3 months ago - 15 years 3 months ago #104779 by sozzled
Replied by sozzled on topic Fresh install? Really??
:D I wrote a topic called Which came first? The template or the forum?
This looks like a case of which came first: the template or Joomla! :ohmy:
