Kunena 6.2.6 released
Question Blank Screen problem after uploading the joomla site to live server
- darthlogan
- Topic Author
That have work for every extension till kunena forums. I downloaded the site and the database, put the live site on maintenance and made a sql database export.
I tested the site on my home server and uploaded many new extensions that worked perfect including Kunena forums.
After testing everything was ok i reuploaded de site and database to the live server and everything works as intended till i tried to open the forum. Blank Screen.
I turned on the debug and heres the error i get:
JDatabaseMySQL::query: 1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Object' at line 1 SQL=Object
Call stack
# Function Location
1 JSite->dispatch() /var/www/vhosts/ci-tec.com.ve/httpdocs/index.php:68
2 JComponentHelper->renderComponent() /var/www/vhosts/ci-tec.com.ve/httpdocs/includes/application.php:124
3 require_once() /var/www/vhosts/ci-tec.com.ve/httpdocs/libraries/joomla/application/component/helper.php:162
4 KunenaApp->__construct() /var/www/vhosts/ci-tec.com.ve/httpdocs/components/com_kunena/kunena.php:881
5 KunenaFactory::getSession() /var/www/vhosts/ci-tec.com.ve/httpdocs/components/com_kunena/kunena.php:341
6 KunenaSession::getInstance() /var/www/vhosts/ci-tec.com.ve/httpdocs/administrator/components/com_kunena/libraries/factory.php:70
7 KunenaSession->__construct() /var/www/vhosts/ci-tec.com.ve/httpdocs/administrator/components/com_kunena/libraries/session.php:43
8 KunenaSession->updateAllowedForums() /var/www/vhosts/ci-tec.com.ve/httpdocs/administrator/components/com_kunena/libraries/session.php:35
9 CKunenaTools->getAllowedForums() /var/www/vhosts/ci-tec.com.ve/httpdocs/administrator/components/com_kunena/libraries/session.php:211
10 KunenaAccess->getAllowedCategories() /var/www/vhosts/ci-tec.com.ve/httpdocs/components/com_kunena/class.kunena.php:503
11 KunenaAccessCommunityBuilder->loadAllowedCategories() /var/www/vhosts/ci-tec.com.ve/httpdocs/administrator/components/com_kunena/libraries/integration/access.php:140
12 KunenaAccess->getAllowedCategories() /var/www/vhosts/ci-tec.com.ve/httpdocs/administrator/components/com_kunena/libraries/integration/communitybuilder/access.php:45
13 KunenaAccessJoomla15->loadAllowedCategories() /var/www/vhosts/ci-tec.com.ve/httpdocs/administrator/components/com_kunena/libraries/integration/access.php:140
14 KunenaAccessJoomla15->acl_get_groups() /var/www/vhosts/ci-tec.com.ve/httpdocs/administrator/components/com_kunena/libraries/integration/joomla15/access.php:53
15 JDatabaseMySQL->loadResultArray() /var/www/vhosts/ci-tec.com.ve/httpdocs/administrator/components/com_kunena/libraries/integration/joomla15/access.php:208
16 JDatabaseMySQL->query() /var/www/vhosts/ci-tec.com.ve/httpdocs/libraries/joomla/database/database/mysql.php:373
17 JError->raiseError() /var/www/vhosts/ci-tec.com.ve/httpdocs/libraries/joomla/database/database/mysql.php:231
18 JError->raise() /var/www/vhosts/ci-tec.com.ve/httpdocs/libraries/joomla/error/error.php:171
19 JException->__construct() /var/www/vhosts/ci-tec.com.ve/httpdocs/libraries/joomla/error/error.php:136
Notice: Use of undefined constant E_RECOVERABLE_ERROR - assumed 'E_RECOVERABLE_ERROR' in components/com_kunena/libraries/error.php on line 136
Fatal error: Call to undefined function error_get_last() in /var/www/vhosts/ci-tec.com.ve/httpdocs/administrator/components/com_kunena/libraries/error.php on line 137
Heres a copy of my Kunena config:
This message contains confidential informationhtaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : rt_nebulae_j15 | author: RocketTheme, LLC | version: 1.5.0 | creationdate: April 28, 2011
<div>Check back soon!</div>enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template default showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 150 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 120 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access communitybuilder integration_login communitybuilder integration_avatar communitybuilder integration_profile communitybuilder integration_private uddeim integration_activity communitybuilder boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0 userlist_count_users 1 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 1
Third-party components: CommunityBuilder 1.4 | UddeIm 2.4
I bet my problem its one of two things: File permisions on some Kunena directory or file, or the fact that my home server dont use the same path for the http directory as the live and Kunena must be pointing at some directory that simply its not there.
heres the site if you need to see it: www.http://ci-tec.com.ve
Many thanks in advance.
You need to have php 5.2.3 to be able to work with kunena correctly.
- darthlogan
- Topic Author
