Question Upgrade from 1.5.12 to 1.6 went ok, but get Fatal error: Class 'KunenaFactory' not found
Really hope someone can help.
I've upgraded 1.5.12 to 1.6 and the process went through with no errors. Now when I try to access the forum from the front end I get the following error:
Fatal error: Class 'KunenaFactory' not found in public_html/dev/components/com_kunena/kunena.php on line 40
I have to revert back to a previous 1.5* version to get it to work again.
Can anyone advise?
Thanks.
Sorry - 1.6.4
Cheers.
Maybe your kunena installation has failed in some ways
Even so ... make sure that you have a reliable backup of your site before you start this process.
So I should try manually deleting some directories on the server after uninstalling Kunena?
Apart from components > com_kunena is there anything else?
If it protects the posts etc. I presume these are all saved in the database and thus not affected as you say?
Ta (I'm pretty new to Joomla as you can probably tell!)
Cheers.
I just wanted to say I finally got round to taking a fresh backup. Upgrading joomla and then the Kunena and all went smoothly. I'm now all sorted.
Thanks for your help.
