Question Posts Not Showing In Forums
15 years 4 months ago - 15 years 4 months ago #100181 by AndyInSpain
Hi All,
I'm doing a site rewrite. I've installed K1.6.4 under a fresh installation of Joomla 1.5.23.
I have imported all the Kunena tables from an older version of my website. This was running K1.6.2 under J1.5.23.
After the import I was notified about the necessity for a database upgrade, which completed without errors.
All appeared to be well. All topic and post counts are showing up correctly in both the back end and front end statistics.
But...when I enter a forum from the front end of the site, I see "There are no posts in this forum." This happens in all forums. It looks like the posts are not matching the categories (that's a guess) but the category table has imported without problems.
I'm sure this is something really simple to rectify. I've recounted the statistics but no change.
Does anybody have any ideas what I've missed?
Many thanks for any help
Andy.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : jsn_epic_pro | author: JoomlaShine.com | version: 4.2.0 | creationdate: 06/22/2011
Last edit: 15 years 4 months ago by AndyInSpain.
15 years 4 months ago #100205 by xillibit
Can-you please descrive exactly how you have proceed to make the upgrade ?
The following user(s) said Thank You: AndyInSpain
15 years 4 months ago #100232 by AndyInSpain
Hi xillibit,
Many thanks for your reply.
I first installed K1.64 under J1.5.23. I then copied all the Kunena tables from my K1.62 installation to my new K1.64 installation, overwriting the existing 1.64 tables. Then, in the 1.64 installation I received a notification that the tables needed to be upgraded because of database design changes. I proceeded with this and the operation completed without error.
Please let me know if you need any further information.
Kind regards and thanks again
Andy.
15 years 4 months ago #100244 by sozzled
I suggest that you reapply the K 1.6.4 upgrade to your copied tables. See K 1.6 Upgrade Guide for further information on how to do this.
15 years 4 months ago #100248 by AndyInSpain
Many thanks Sozzled. I shall try that. Here's hoping!
15 years 4 months ago #100251 by AndyInSpain
OK, I tried that and although the installation seems to have completed OK there has been no change, i.e. posts are still not visible in forums. Is there anything else I can try? Is it possible there is a table I omitted to copy over which might be causing this problem?
Many thanks
Andy.
