Question Problem when installing
15 years 6 months ago - 15 years 6 months ago #96045 by retrojc
Tried installing 1.6, as i couldn't get 1.5 to work with seo, but I got this error message:
Warning: require_once(/home/thisscom/public_html/administrator/components/com_kunena/api.php) [function.require-once]: failed to open stream: No such file or directory in /home/thisscom/public_html/administrator/components/com_kunena/admin.kunena.php on line 29
Fatal error: require_once() [function.require]: Failed opening required '/home/thisscom/public_html/administrator/components/com_kunena/api.php' (include_path='.:/usr/lib/php') in /home/thisscom/public_html/administrator/components/com_kunena/admin.kunena.php on line 29
any ideas?
Edit, if you check my posts, I've had nothing but problems with junenea, which is a shame as i think its great. But i'm going to see what other forums are avaiable! :(
Last edit: 15 years 6 months ago by retrojc.
15 years 6 months ago #96051 by xillibit
Please check the requirements : docs.kunena.org/index.php/K_1.6_Technical_Requirements
15 years 5 months ago - 15 years 5 months ago #96089 by sozzled
Replied by sozzled on topic Re: Problem when installing
retrojc: Xillibit is actually 100% correct when he says that you need to read K 1.6 Technical Requirements .
Even more importantly, you should read K 1.6 Installation Guide .
Do you want to know how long it takes to build a complete website with Joomla, SEO, a 100% fully working Kunena discussion forum and fully backed up? It should take you no more than 1 hour 15 minutes. It's true; I've done it. If you're using a Fantastico script to install Joomla, you can probably cut about 45 minutes off that time. But it does depend on the answer to this question: Which came first: the template or the forum?
Last edit: 15 years 5 months ago by sozzled.
15 years 5 months ago #96926 by retrojc
Replied by retrojc on topic Re: Problem when installing
i checked that i met the requirements before i installed.
The site came first
15 years 5 months ago #96936 by sozzled
Do you have a config report?
15 years 5 months ago #96937 by xillibit
When do you see this message ?
The installation of Kunena is finished or you are stuck in the middle of installation.
