Important [RESOLVED] upgrade joomla 1.6.1 to 1.6.2 and Kunena 1.6.3
15 years 3 weeks ago - 15 years 2 weeks ago #92257 by 56francesco
after upgrading from 1.6.1 to 1.6.2 of the joomla superadmin can no longer manage and edit categories and users Kunena
I'm stuck, I can intervene in the database, or is there any option to unblock the situation? please is there any solution?
Last edit: 15 years 2 weeks ago by 56francesco.
15 years 3 weeks ago #92259 by xillibit
You need to wait k1.6.4 which will fix plenty of issues
15 years 3 weeks ago #92261 by 56francesco
Thanks very much for your quick response.
Get there
15 years 3 weeks ago - 15 years 3 weeks ago #92316 by sozzled
I'm sorry, but I think we need to emphasise a very important fact.
Kunena 1.6.3 is not fully compatible with Joomla 1.6.x
The technical requirements clearly states the following:
Users may want to experiment with K 1.6 and Joomla 1.6. K 1.6.2 provides some capability to work with Joomla 1.6 and this capability will be extended in future releases. There are issues with installing or using K 1.6.x in Joomla 1.6 at this time. Some of these issues are show-stoppers if users are considering Joomla 1.6 to run their production websites. Many of these issues will be fixed in future versions of Kunena and Joomla. At this time users are encouraged to report issues with Joomla 1.6 as test cases but support may not necessarily be available to resolve them. Until otherwise advised, please use the K 1.6 test reports category to report issues that you are having with K 1.6 and J! 1.6. Until accepted by the Joomla Extensions Directory as a native Joomla 1.6 extension, K 1.6 is not a Joomla 1.6 native extension.
That is the whole point.
K 1.6.4 will improve Kunena's compatibility with J! 1.6 but, until the Joomla Extensions Directory gives its endorsement, K 1.6 is not ready to be classed as a Joomla 1.6 native extension.
K 1.6.4 will fix a lot of issues; some of those issues affect Kunena' interoperability with J! 1.6. J! 1.6.2 fixes a lot of issues with J! 1.6, too. K 1.6.4 will not work 100% under J! 1.6.1 and, no matter how much tinkering people try to do, people will need to use J! 1.6.2 or some future release of J! 1.6 (if there is going to be a future release) before all these interoperability issues are fully resolved.
Last edit: 15 years 3 weeks ago by sozzled.
15 years 2 weeks ago - 15 years 2 weeks ago #92541 by priestsjaak
Having the same issues and starting to dig into the why's.
It is not only Kunena dealing with this latest joomla patch.
This patch contains a HUGE bug...stay from it for now till a solution has been published by Joomla.
Read more about why it broke so many so called 3rd party extensions:
joomlacode.org/gf/project/joomla/tracker...racker_item_id=25657
cheers and hope its of any help 2u on getting some answers.
[EDIT]:
In short: Joomla will fire an emergency fix as likely as today or tomorrow as 1.6.3
Last edit: 15 years 2 weeks ago by priestsjaak.
15 years 2 weeks ago #92637 by 56francesco
With joomla 1.6.2 it was impossible to enter into variation in the categories of the forum, now after upgrading to joomla 1.6.3 FireBoard has returned to work correctly.
Waiting for FireBoard 1.6.4 I'm doing a project and I must say that I am very well.
Thanks for all your help.
Time to create page: 0.263 seconds
