Question Problem with Kunena Latest after upgrade
15 years 8 months ago #88396 by bigmike0601
Test site running K1.6.3: oceancity2do.com/user-blogs
Live site running K1.5: easternshoreman.com/user-blogs
As you can see, upon upgrade the Kunena Latest module doesn't good. Any help is appreciated.
Thanks,
Mike
15 years 8 months ago #88398 by xillibit
This is a template issue with your Joomla! template
15 years 8 months ago #88401 by bigmike0601
xillibit wrote: Hello,
So, i need to change my joomla template to meet kunena requirements?
15 years 8 months ago - 15 years 8 months ago #88419 by sozzled
You can't use that version of "latest posts" in K 1.6. See K 1.6.3 release notes .
You need to uninstall any modules, plugins, that you might have been using with K 1.5 before you upgrade to K 1.6. ;) The upgrade procedure will leave your old K 1.5 template in place but it won't be (and it can't be) used in K 1.6.
As far as your template is concerned, it "depends". See K 1.6 Technical Requirements . Usuaully, Joomla site templates designed before June 2010 are more likely to have "legacy issues" than the newer templates or the ones that come standard with Joomla.
15 years 8 months ago #88428 by bigmike0601
The Kunena Latest Module is the most current one. I installed it just today. So, this must mean my joomla template is not compatible?
15 years 8 months ago #88432 by sozzled
Please post your K 1.6 configuration report. This will help a lot. (See also PM I sent to you)
