Question 404 componenet not found error in kunena 1.6.3
15 years 9 months ago #85421 by msg4wale
i just installed the kunena 1.6.3 on my site at www.abokee.com . i recieve the 404 componenet not found erorr when a link is cliked.
htaccess: Exists | PHP environment: Max execution time: 16000 seconds | Max execution memory: 512M | Max file upload: 400M
Joomla default template details : ja_purity | author: JoomlArt.com | version: 1.2.0 | creationdate: 12/26/07
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 2.0.5) | UddeIm: Disabled or not installed
15 years 9 months ago #85425 by xillibit
You have an issue with your sef rewriting, in Joomla! configuration panel do you havbe tried to enable the Joomla! sef rewrite ?
15 years 9 months ago #85434 by msg4wale
i initially had friendly url and url suffix set to yes in my joomla global configuration. but i unset them some few munites ago and the error appears to be corrected. how can i enable sef url or use a sef extension without experience this error again?
15 years 9 months ago #85465 by sozzled
I wish I understood why it seems to be the case that so many people have difficulty with Joomla SEO. When we learn why these issues seem to occur so many times, we might be able to find a way to prevent them happening.
I don't think the problem is just a Kunena problem; I think this is Joomla menu problem.
Question for msg4wale: how many ways can you get to your Kunena forum? In other words, I see the "Forum" link on the left menu on your site. Do you have any other links like this?
15 years 9 months ago #85580 by msg4wale
no that's the only link to the forum for now. i also intend including it on the jomsocial toolbar just like we have it on this site kunena.org
15 years 9 months ago #85597 by sozzled
Thank you for your answer.
404 errors are usually generated by Joomla when you have a menu problem and, nearly all of them, if you have not properly setup SEO. That's what xillibit was trying to say. That's what I was trying to say.
There is a guide in the Wiki. Please read it very carefully.
Joomla SEO is not just two radio buttons on the Global configuration. Those radio buttons are the easy part - anyone can do that! The second ingredient is the .htaccess file. So, just to be sure, read that guide again and pay attention to the words written about .htaccess file. Good luck. :)
