Important Parse error: /administrator/components/com_kunena/install/model.php on line 37
I'm trying to install com_kunena_v1.6.3 in Joomla! 1.5.10.
Initially, I received the error:
I created this folder manually, and gave it permissions 2777.JFolder::create: Could not create directory
Component Install: Failed to create directory.: "/components/com_kunena"
Now, I receive the error:
Parse error: syntax error, unexpected T_STRING, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or '}' in /administrator/components/com_kunena/install/model.php on line 37
Why is this happening? How do I fix it?
Thanks.
The requierments for this version is Joomla! 1.5.22
The second error indicate that you have some files which are corrupted, re-download it.
I have twice downloaded a new copy of com_kunena_v1.6.3_b4344_2011-01-31.zip and tried to install it, only to receive exactly the same error.
Maybe the zip file on your server is corrupt?
- Thank you received: 2545
It also gives this error message when using php 4.xParse error: syntax error, unexpected T_STRING, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or '}
What is wrong with PHP4?
Kunena 1.6 needed PHP5.
