Question Installation issue in joomla 1.6
15 years 10 months ago #80815 by skkuumar
Hi all
I cant able to install kunena 1.6.2 in Joomla 1.6.
getting error as There was an error uploading this file to the server.
help me to solve this issue
regards
Kumar
15 years 10 months ago #80851 by xillibit
Install kunena with the directory function into extension menu manager
15 years 10 months ago - 15 years 10 months ago #80853 by TauxFu
Try using the URL install path with this URL (or you can get it from the file area of this site)
joomlacode.org/gf/download/frsrelease/13...94_2010-12-29.tar.gz
I had the same problem, this worked instantly.
Last edit: 15 years 10 months ago by TauxFu. Reason: Found a solution
15 years 10 months ago #80878 by zzyzxnomad
This is the error I recieve when installing based on the process described above.
JLIB_APPLICATION_ERROR_COMPONENT_NOT_LOADING
This is impacting the final install and causing errors.
Any advice as to what is causing this?
Nomad
15 years 10 months ago #80881 by etusha
wait for K1.6.3 is more compatible with J!1.6
