Important K 1.5.5 -> K 1.6.2 upgrade issues
15 years 10 months ago - 15 years 10 months ago #79781 by tanuck
I just upgraded kunena to 1.6.2 and since the client side of my site displays a blank white page only. No error code given. Very strange!
Any ideas guys?
Tanuck
Last edit: 15 years 10 months ago by sozzled.
15 years 10 months ago #79782 by tanuck
Replied by tanuck on topic Re: Upgrading to 1.6.2
*Amendment*
I restored the site from a backup now:
joomla 1.5.22
kunena 1.5.5
Any ideas whats going wrong with this upgrade?
15 years 10 months ago #79796 by xillibit
Do you meet the requierements : docs.kunena.org/index.php/Kunena_1.6.2_R...#System_Requirements ?
Like that it's difficult to say something, if you can make a copy of you site and then upgrade to kunena 1.6.2. Then enable debug mode in Joomla configuration panel to see if you see some errors.
15 years 10 months ago #79797 by sozzled
Please read very carefully the release notes for K 1.6.2 .
I think that the reason your website has a "blank page" is because you were running an add-on that was designed for an old version of Kunena (or Fireboard). If you turn on Joomla debug mode you will probably see the error message that will confirm this fact.
K 1.5.5!! Wow! That's pretty old! Even so, the K 1.6 installation process has been tested successfully with many old versions of Kunena and so it should not be your specific version that is causing the problem. As you implied, the upgrade procedure completed successfully. It was only when you tried to use the forum that you had problems. The white page indicates that you are running incompatible software with Kunena.
