Question upgrade failed Fatal error: Class 'KunenaRouter' not found in>>
15 years 10 months ago #79371 by benjamin2
Hi>>
I tried to upgrade from 1.6 to 1.6.2 ...
after finish and when I open the forum this error apears:
Fatal error: Class 'KunenaRouter' not found in /home/ahebataz/public_html/components/com_kunena/funcs/latestx.php on line 150
Plz help
15 years 10 months ago #79380 by benjamin2
htaccess: Exists | PHP environment: Max execution time: 180 seconds | Max execution memory: 128M | Max file upload: 12M
Joomla default template details : yoo_air_ar_by_joomlana | author: Omar Al Tahan | version: 5.5.0 | creationdate: October 2010
Kunena default template details : قالب جوملانا البني | author: عبدالله بازهير baazza | version: 2.2.0 | creationdate: 2010-09-13
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.0)
15 years 10 months ago #79386 by benjamin2
I reupload the router.php file and the error gone ... but the forum is still close for construction (Forum is currently closed for maintenance) !!
15 years 10 months ago #79389 by xillibit
In kunena configuration panel, you have a configuration setting do set forum offline or not.
15 years 10 months ago - 15 years 10 months ago #79393 by benjamin2
it is currently set to not ..But when I want to browse the forum is closed for maintenance
Last edit: 15 years 10 months ago by benjamin2.
15 years 10 months ago #79404 by xillibit
Why you don't set it to on ?
