Question Where's my forum? Please help!
- Nondescript
I'm running Joomla 1.5 and have just installed 1.6 of Kunena. From the backend everything looks good. The install went without a hitch. I've published the menu item for the forum but when i click on the link from my site, i get a 404 error-page cannot be found.
I'm a newbie to Joomla and I can't figure out what the problem is. I've tried recreating the menu through the Kunena control panel but this doesn't fix it. The menu item i create for Kunena links me to www.mywebsite.com/forum . Is that how correct for Kunena? I'm really confused and don't know where to go next.
If anyone could help i'd be really grateful
thanks so much
Cheers
Chris
- snilloconator
- Premium Member
- aka snilly
- Nondescript
Thanks for taking the time to respond. After a few hours I stumbled on an article which advised you to turn off the SEO settings in Joomla global config, and comment out a line of code in .htmaccess. I then switched the SEO settings back on and it's working now.
Cheers
Chris
Where is this article, please? Is it on this website? If it is on this website, I want to look at it very closely because this is not something that is encouraged by this project.Nondescript wrote: After a few hours I stumbled on an article which advised you to turn off the SEO settings in Joomla global config, and comment out a line of code in .htmaccess.
It is preferable, from a security viewpoint, to use Joomla Search Engine Optimization (SEO) . It is not only preferable, it is strongly encouraged that people should do this! Very strongly encouraged. If there is an article on this website that says, in effect, "turn off SEO settings in the Joomla global configuration" then I would sincerely hope that this suggestion was being offered in a very rare case. As a general rule, people should turn on, and leave turned on, Joomla SEO in the way that is outlined in Search Engine Optimization (SEO) in the Wiki.
I hope that we will soon get to the truth about this case.
- Nondescript
This is the article i mentioned:
www.kunena.org/forum/139-k-15-support-ar...g-w-kunena-404-error
I am running with Joomla SEO switched on now. You just turn it off, edit the file, then turn back on and Kunena starts working.
I'm impressed that you guys take issues like this so seriously. Great support. Thanks a lot. If you find any more information about this please let me know.
