Question "Invalid argument" warning given after 1.6.0 to 1.6.1 upgrade
15 years 9 months ago #76466 by cbird01
Any other suggestions on this? Thanks
15 years 9 months ago #77745 by rossi256
Hi, i have a similar problem - i am on 1.6.1 now. The permissions in my files are right.
the package in the earlier post contains a 390 byte router.php - using this file to replace the file in the installed component results in a blank website and php errors...
My error log shows
Invalid argument supplied for foreach() in /components/com_kunena/router.php on line 150
every now and then...
Any help welcome
Kind regards
15 years 9 months ago #77747 by xillibit
The router.php file has a weight of 10 Kbytes, try with this one :
File Attachment:
File Name: router.zip
File Size:3.26 KB
15 years 9 months ago - 15 years 9 months ago #77775 by cbird01
I still get
"Warning: Invalid argument supplied for foreach() in /home/[username]/public_html/components/com_kunena/router.php on line 150"
It looks like the file you supplied is the same one that is supplied with the original upgrade package to 1.6.1, that caused the original error. They are the exact same size.
Last edit: 15 years 9 months ago by cbird01.
15 years 9 months ago - 15 years 9 months ago #77777 by cbird01
I am seeing the same problem with the 390 byte file supplied in the original package referenced "com_kunena_v1.6.1_b3858_2010-11-06" - site goes down
15 years 9 months ago #77823 by xillibit
Please put here your kunena report configuration.
Time to create page: 0.218 seconds
