Question Why Always Problematic ?
16 years 1 week ago - 16 years 1 week ago #70412 by jetwong98
Last time, when I tested Kunena 1.6 Beta/RC, it caused problems over to my system and I never used Kunena since then.
Now, I downloaded this latest package 1.6.1, when I installed it on the Justhost web hosting server, during the below installation screen, it was suddenly logged out back to the Joomla Administrator Login screen.
When I login back to Admin, it is said that Kunena 1.6.1 was installed but I doubt if it will be stable. Then I re-upload and install the package, it prompts me 2 options whether to Reinstall or Remove 1.6. I selected Remove 1.6 and it was prompted with a successful uninstallation msg.
I re-upload and install the package again, when I clicked install, the following message was shown.
Then, I installed a Fresh Joomla and tried Kunena again, during the installation screen, Kunena was still logged out to Joomla Administrator Login Screen unexpectedly. Is it the problem with JustHost Server ? The installation process is just smooth on my laptop running WinXP, PHP 5 + Apache 2.2.
Honestly, very fed-up with Kunena now posing me lots of funny issues since 1.6 testing version till now.
Thanks.
Last edit: 16 years 1 week ago by jetwong98.
16 years 1 week ago #70418 by xillibit
PLease report your configuration settings, see the second part : docs.kunena.org/index.php/K_1.6_Configuration_Report
16 years 1 week ago - 16 years 1 week ago #70471 by jetwong98
xillibit wrote: Hello,
As follows. Just to correct the earlier statement, Fresh Joomla with Kunena installation on Justhost server is OK.
I doubt if Kunena installation is in conflict with other 3rd-party Plugins on the production site on Justhost server. However, if I use akeeba backup to clone and restore the production site onto my Laptop, Kunena installation works until the finished button displayed, didn't log out in the middle unexpectedly. Is it funny ?
Joomla! Environment Discovery
Joomla! Version Joomla! 1.5.22 Stable [ senu takaa ama woi ] 04-November-2010 18:00 GMT
configuration.php Writable ( Mode: 777 )
RG_EMULATION N/A
Host Environment Discovery
Architecture x86_64 ( Linux )
Platform Linux 2.6.32.13-grsec
#1 SMP Thu May 27 11:21:51 CDT 2010
Web Environment Discovery
Web Server Version Apache
Web Host www.xxxx.com
PHP Environment Discovery
PHP Version 5.2.13
register_globals Disabled
magic_quotes_gpc Enabled
safe_mode Disabled
MySQL Yes
xml Yes
zlib Yes
mbstring Yes
iconv Yes
save.session_path /tmp
Writable
Max. Execution Time 30 seconds
File Upload Enabled
MySQL Environment Discovery
MySQL Server Version 5.0.91-community
Host Info Localhost via UNIX socket
SEF Disabled (without ReWrite)
Legacy Mode Disabled
FTP Layer Disabled
htaccess Implemented
Current Path /home/xxxx/public_html/main
Document Root /home/xxxx/public_html
Server Acc.
User Acc. xxxx
xxxx
User and Web Server accounts are the same. (PHP/suExec probably installed)
PHP API cgi
MySQLi Yes
Max. Memory Limit 64M
Max. Upload File Size 10M
Max. Post Size 8M
Max. Input Time 60
Zend Version 2.2.0
Disabled Functions No Disabled Functions
Client Version 5.0.91
Character Set latin1
16 years 1 week ago - 16 years 1 week ago #70492 by jetwong98
I found the problems already. After I cloned and restored the Production Site onto my laptop from the Justhost server, I tried installing Kunena on the restored version on my laptop. The following error screen prompted but it didn't logout to the administrator login page as on the Justhost server.
It carried on until the following screen showed.
On the Justhost server, these 2 error screens NEVER showed but immediately logout to the administrator login page when the problem hit. Why is it so ?
I only installed Traditional Chinese language for the Front-end, not backend, why does it bother with Kunena 1.6.1 during installation ? It took me 10 hours on troubleshooting and the problem is bcoz of this language issue.
Sigh, bitter experience again and Kunena 1.6.1 is yet stable in terms of installation. I'm wondering why Justhost server didn't prompt the errors. Fortunately, my laptop did, otherwise I won't know the issue behind until the doomsday, wasting me so....much time on this silly bug.
Thanks Akeeba Backup, your user-friendly clone-n-restore functions help me a lot on simulation.
16 years 1 week ago #70637 by jetwong98
I've many websites installed with multilingual features, could you please please please look into troubleshooting this issue ?
In order to install Kunena 1.6.1, I have to uninstall the language packs other than English otherwise the installation process will be terminated and jump to the Administrator Login Screen when the problem hit as stated in earlier posts.
I'm tired with Kunena since 1.6 Beta and this 1.6.1 seems problematic too. If I raised up this issue with Justhost, they'll say this is mainly Kunena problems. Why does kunena bother with other languages during installation ? Why is it terminated on justhost server but not on my laptop ?
Million Thanks
16 years 1 week ago - 16 years 1 week ago #70678 by fxstein
This is clearly something we need to get a better handle on.
Some of the foreign translations are broken. What we get submitted by the community does not always work. It seems both Russian and Taiwanese language packs had incorrect xml files.
Kunena only installs languages presently installed within Joomla. So if your laptop has different languages than your host, Kunena will install different language packs.
Since none of these seem to get installed by any of our existing testers, they don't get caught before release.
1.) Would you mind joining the tester team? You would have access to pre-builds and could help us test this before we release
2.) We need an install option that installs all languages, to make sure we get all installs tested all the time.
Last edit: 16 years 1 week ago by fxstein.
