Question Joomla 1.5.22 and kunena 1.6.1 JFolder::create: Could not create directory
15 years 10 months ago - 14 years 10 months ago #70715 by sozzled
We do not recommend CHMOD 777 for files or folders. See Securing Kunena .
Last edit: 14 years 10 months ago by sozzled.
15 years 10 months ago #70723 by fxstein
Permissions issues are hard to remote diagnose. If Joomla complains that it cannot create a folder or write a file, we know one thing for sure: it is definitely a permissions issue on that server.
Never should a permissions problem be solved by removing permissions with chmod 777.
To start I recommend you run
ls -la
Inside your joomla main directory. Take a screen shot of the output and post it in here - preferably inside confidential become tags so only we can see it.
In addition please go to the Joomla backend and also take a screenshoot of the Joomla directory permissions screen.
That should give us an idea how your system permissions are setup.
15 years 10 months ago #71181 by Gamekeeper
My hosts have now installed suPHP which allows me to set CHMOD to recommended values
Time to create page: 0.245 seconds
