Question Installation breaks up with blank page
16 years 1 month ago #67188 by JanD
because I haven't found any topics that match with my situation, I'll try with this new one. It seems not to be a kunena problem but appears with this addon.
I do not succeed to install the latest version of kunena on a special webspace (goneo.de). First I thought, that I've damaged the installation, so I deleted all Joomla folders and files and the database. I reinstalled the latest joomla version and only kunena, but the same things happen: The page was loading and after a few seconds changed to a blank one.
The kunena menu is to see in the frontend but leads to blank pages. The folders in the component and module directory were created, the entries in jos_components too, but not the mysql tables of kunena. I have to clear the installation manually because removing of kunena also breaks up with a blank page.
I've checked the "before install" list and discovered that the whole joomla installation crashes into blank if I activate the mootools plugin.
As there are no such problems on another webspace and on a local installation, I conclude a special server configuration, but haven't found the answer yet.
Anyone who knows the reason or have any idea what I can try next?
16 years 1 month ago #67195 by xillibit
Which Joomla! version do you have ? Do you have tried to install k1.6.0 stable ?
Can-you check please in your php log or apache log, if you some errors ?
16 years 3 weeks ago #68630 by JanD
Sorry for the delay.
It's Joomla 1.5.21 and Kunena 1.6.0.
I've figured out now, that the error occures on php 4.4.9, not with 5.2.9.
By activating the mootools plugin the following error is reported:
"Parse error: syntax error, unexpected T_OBJECT_OPERATOR in /web/1/000/035/440/.../htdocs/.../plugins/system/mtupgrade/behavior.php on line 52"
Are there other solutions than updating the php version?
16 years 3 weeks ago #68634 by xillibit
JanD wrote: Sorry for the delay.
You have this error with php 5.2.9 ?
Try to replace with FTP the file plugins/system/mtupgrade/behavior.php in your system, i think it's corurpted
16 years 3 weeks ago #68715 by JanD
I'm surprised by the information you get from my post :( Apperently I don't succeed in make myself clear.
If I activate the mootools plugin or install kunena 1.6.0 stable on a webspace with php 4.4.9 I'll get a blank page. On a webspace with php 5.2.9 everything is fine!
It also happened if the mysql database and the joomla-directory is empty and I only install joomla 1.5.21 and, without any changes, kunena 1.6.0.
I don't suppose mistakes in my doing and don't think that a corrupt file is the reason because I deleted and uploaded the whole installation more than once and I succeed on other webspaces/local installation.
16 years 3 weeks ago #68724 by xillibit
So, now it's fixed ?
