Question Upgrading Problems 1.6
16 years 1 month ago #65079 by Krosan
I tried today to upgrade the kunena forum i'm runing from 1.5.12 to 1.6
First i uninstalled the old version and afterwords i tried to install it again but everytime when i try upload and install its taking some time and afterwards nothing is happen, some kind of timeout.
So i thought maybe its a problem with the provider and uploaded the folder into the temp directory and run the installation from there. Now it worked and he is asking if i wanna migrate if i click this i have the same problem again.
I reinstalled the old version 1.5.12 which is now running again and if i try to make an upgrade without uninstallation i get this error: Fatal error: Class 'DOMDocument' not found in <pathtoside>/administrator/components/com_kunena/install/schema.php on line 188
i tried
update joomla to 1.5.21
deaktivated all components and plugins which where additionaly installed
but its still not running
can somebody maybe help me?
thanks
16 years 1 month ago #65113 by xillibit
Replied by xillibit on topic Re: Upgrading Problems 1.6
You need to have at least PHP 5.2.3 and MySQL 5.x to install kunena 1.6
Maybe try to increase the php memory limit and the maximum execution time in your php.ini
16 years 1 month ago #65115 by fxstein
Replied by fxstein on topic Re: Upgrading Problems 1.6
FYI - You don't have to uninstall a prior Kunena version - Out upgrader does the upgrade for you.
16 years 1 month ago #65159 by Krosan
Replied by Krosan on topic Re: Upgrading Problems 1.6
xillibit wrote: Hello,
thanks fo the answer the mysql version is 5.1.49 and the php version is 5.3.3
its hosted on an webpage so i can not change the php settings
max_execution_time 20
memory_limit 128M
is this enought or to small/short? if its to short i'll try it lokal
yes i tried this too like i posted.
16 years 1 month ago #65185 by sozzled
Replied by sozzled on topic Re: Upgrading Problems 1.6
Please read Kunena 1.6.0 Read Me: System Requirements for details of minimum system requirements to run K 1.6.0.
Your system memory should be sufficient but the max. execution time might be a little low. This is something that you will need to discuss with your web hosting provider.
