Question Installing RC3 over RC2 gives language error
16 years 1 month ago #62082 by Webguy101au
Hi All, RC worked well for me, I just saw RC3 was out so have tried to upgrade and get a language error...
Prepare Installation ... OK
Migrate fb_version ... OK
Alter kunena_version ... OK
Uncompressing admin.tar ... OK
Uncompressing site.tar ... OK
Uncompressing media.tar ... OK
Installing language German (Deutschland) ... OK
Installing language English (United Kingdom) ... OK
Installing language Spanish(Español Internacional Formal) ... OK
Installing language French (FR) ... OK
Installing language Magyar (Hungary) ... Failed
Now, My forum is offline and all it wants to do is try and keep trying to upgrade, any suggestions?
Cheers
16 years 1 month ago #62193 by xillibit
In which language do you have setted Joomla! ?
16 years 1 month ago #62195 by Webguy101au
English - United Kingdom. Any suggestions? One error message said that the language that caused the error did not have something or other in there. (Yeah I know, I never wrote it down, sorry)
16 years 1 month ago #62197 by Webguy101au
The actual error...
* Language Name Install: No core pack exists for the language :hu-HU
* The Kunena forum could not be installed!
16 years 1 month ago #62210 by fxstein
Work around: There seems to be a bug in the supplied hungarian language pack.
To bypass this error, please uninstall the hungarian language in Joomla it self and reinstall Kunena.
Once Kunena is installed you can reinstall the Joomla language pack.
For not the hungarian language will not be available on your site inside of Kunena.
Will that work until we have a fix for it?
The following user(s) said Thank You: Webguy101au
16 years 1 month ago - 16 years 1 month ago #62305 by Matias
Another way to do it is to remove hu-HU from Kunena zip.
If you need the language, you can extract it and look at the xml file. If you find a way to fix the file, you can install it by using Joomla installer.
Last edit: 16 years 1 month ago by Matias.
