Question Erroneous Requirements Check Failure
16 years 2 months ago #60398 by jayx2thez
The Kunena 1.6 RC2 installer is refusing to work due to an erroneous requirements check failure on my Joomla version:
REQUIREMENTS CHECK: FAILED - Minimum version requirements not satisfied
PHP version: 5.2.14 (Required >= 5.2.3)
MySQL version: 5.1.48 (Required >= 4.1.19)
Joomla version: 1.5.9 (Required >= 1.5.19)
Please assist, as I'm trying to upgrade in order to acquire polling functionality as soon as possible
Thanks!
--Jay
16 years 2 months ago #60400 by jayx2thez
Another thing, my forum is currently offline, and whenever I try to access the old component to put the forum back online, it takes me to the requirements error page :(
16 years 2 months ago - 16 years 2 months ago #60402 by sozzled
You need PHP version 5.2.3 or above. You need Joomla 1.5.19 or above. These things are written about in the Technical Requirements .
The K 1.6 installer takes your forum offline. Theoretically you should be able to put your forum back online again by changing your configuration settings in the backend. I don't know why you don't seem to be able to make that change and I'm not sure what you need to do about it. I'll try to get an answer for you
16 years 2 months ago #60403 by fxstein
Please upgrade your Joomla version from 1.5.9 to 1.5.19 or higher (currently 1.5.20) and you will be fine.
16 years 1 month ago #64923 by Jingz
I am having the same error.
MySQL version: 5.0.91-log (Required >= 4.1.19)
Joomla version: 1.5.15 (Required >= 1.5.20)
I tried to upgrade my joomla but somehow after upgrading to joomla v. 1.5.21, the backend still shows 1.5.15. Don't understand why... :(
16 years 1 month ago #64928 by xillibit
are-you sure that you have replace all files provided in update package ?
