Question Duplicate entry at jos_kunena_messages - Upgrade from 1.5.12
16 years 1 month ago #59312 by poliscas
Hi I've just upgraded from 1.5.12 and whole procedure was smooth.
I can read and browse old entries ==> migrated to new forum fine.
But, I can not post a new message, because I receive this error:
500 - JDatabaseMySQL::query: 1062 - Duplicate entry '0' for key 1 SQL=INSERT INTO jos_kunena_messages (`name`, `email`, `subject`, `topic_emoticon`, `ip`, `userid`, `parent`, `thread`, `catid`, `time`, `hold`) VALUES....
Any idea ? Thx.
16 years 1 month ago #59314 by poliscas
I cheked the last row at jos_kunena_messages and it's like:
id =0
parent =0
thread =0
I erased that retried and gave the same result...
16 years 1 month ago #59318 by poliscas
Here are my details:
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 60M
Kunena version detailled: Installed version: 1.6.0-RC1 | Build: 3173 | Version name: Kujadili | Kunena detailled configuration:
16 years 1 month ago #59351 by xillibit
poliscas wrote: But, I can not post a new message, because I receive this error:
Any idea ? Thx.
Can-you give please the entire error message ?
16 years 1 month ago #59365 by Matias
It looks like you're missing primary key. Did you earlier convert the forum from Joomla 1.0?
Try this URL in your site and report your findings into here:
/administrator/index.php?option=com_kunena&view=install&layout=schema
16 years 1 month ago - 16 years 1 month ago #59367 by poliscas
Here is the error message:
500 - JDatabaseMySQL::query: 1062 - Duplicate entry '0' for key 1 SQL=INSERT INTO jos_kunena_messages (`name`, `email`, `subject`, `topic_emoticon`, `ip`, `userid`, `parent`, `thread`, `catid`, `time`, `hold`) VALUES('admin', '[email protected]', 'Αυτό είναι ένα δοκιμαστικό μήνυμα', '1', '87.202.168.141', '62', '0', '0', '30', '1283289461', '0')
Matias I tried this url but it gives
500 - Kunena function "install" not found
And yes the forum is converted from Joomla 1.0
Last edit: 16 years 1 month ago by poliscas.
Time to create page: 0.265 seconds
