Question Frontend blank after upgrade to 1.6 RC1
15 years 8 months ago #58576 by DigitalMediaGuy
Yesterday I attempted to upgrade Kunena to 1.6 and crashed the front end of my site. Everything was a blank page!
The backend worked except for kunena... If I clicked the kunena component it would also go blank... I had to do a full restore so I didn't get a change to generate the error logs from the backend like you like... I did however turn on error reporting in joomla and got the following back:
Notice: Use of undefined constant KUNENA_ABSSOURCESPATH - assumed 'KUNENA_ABSSOURCESPATH' in /var/www/vhosts/MYSITE.com/httpdocs/components/com_kunena/template/default/smile.class.php on line 27
Warning: include_once(KUNENA_ABSSOURCESPATHkunena.parser.base.php) [function.include-once]: failed to open stream: No such file or directory in /var/www/vhosts/MYSITE.com/httpdocs/components/com_kunena/template/default/smile.class.php on line 27
Warning: include_once() [function.include]: Failed opening 'KUNENA_ABSSOURCESPATHkunena.parser.base.php' for inclusion (include_path='.:/var/www/vhosts/MYSITE.com/httpdocs/plugins/system:.:') in /var/www/vhosts/MYSITE.com/httpdocs/components/com_kunena/template/default/smile.class.php on line 27
Notice: Use of undefined constant KUNENA_ABSSOURCESPATH - assumed 'KUNENA_ABSSOURCESPATH' in /var/www/vhosts/MYSITE.com/httpdocs/components/com_kunena/template/default/smile.class.php on line 28
Warning: include_once(KUNENA_ABSSOURCESPATHkunena.parser.php) [function.include-once]: failed to open stream: No such file or directory in /var/www/vhosts/MYSITE.com/httpdocs/components/com_kunena/template/default/smile.class.php on line 28
Warning: include_once() [function.include]: Failed opening 'KUNENA_ABSSOURCESPATHkunena.parser.php' for inclusion (include_path='.:/var/www/vhosts/MYSITE.com/httpdocs/plugins/system:.:') in /var/www/vhosts/MYSITE.com/httpdocs/components/com_kunena/template/default/smile.class.php on line 28
Notice: Object of class CKunenaConfig could not be converted to int in /var/www/vhosts/MYSITE.com/httpdocs/components/com_kunena/lib/kunena.link.class.php on line 195
Fatal error: Call to a member function isAdmin() on a non-object in /var/www/vhosts/MYSITE.com/httpdocs/components/com_kunena/class.kunena.php on line 502
15 years 8 months ago #58603 by Matias
It looks like you had old 3rd party modules/plugins from Kunena 1.5 installed. They do not check Kunena version. They just try to use functions -- and fail because of most of the code has been changed in Kunena 1.6.
So it was not Kunena that caused this -- you get the same error by uninstalling Kunena 1.5.
You need to remove all old modules and plugins that you have installed for Kunena 1.0/1.5 before installing Kunena itself. That includes CB forum plugin if your CB version is <1.2.3 (CB plugin issue has been fixed later).
Time to create page: 0.263 seconds
