Question 406 Not Acceptable Error when installing
14 years 6 months ago - 14 years 6 months ago #123496 by Bkoubs
Have a fresh install of Joomla 2.5.4, downloaded Kunena 1.7.2, go to extensions and install and I get the following error:
Not Acceptable
An appropriate representation of the requested resource /administrator/index.php could not be found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
We are running:
Apache version 2.2.22
PHP version 5.3.10
MySQL version 5.1.62-cll
I have searched for similar errors and someone suggests to make sure .htaccess is enabled in the joomla root directory and ensure mod-rewrite is on. Well looking through the .htaccess file I see the entry: RewriteEngine On
So I assume that is ok, but what do they mean make sure the .htaccess file is enabled? Any help appreciated.
Last edit: 14 years 6 months ago by Bkoubs.
14 years 6 months ago #123508 by sozzled
G'day, Bkoubs, and welcome to Kunena.
The K 1.6 & K 1.7 Installation Guide provides a lot of information that should help. In particular, you should look at Securing Kunena for information about how to properly setup the folder and file permissions and Search Engine Optimisation (SEO) for advice how to properly setup SEO (and, by extension, your .htaccess file) for a standard Joomla website.
I hope this helps in your case.
14 years 6 months ago #123513 by Bkoubs
No that did not help me. I read through the information, not understanding all of it, I watched the YouTube video and that just doesn't help. I have installed Joomla 1.5 before and installed Kunena before and never had problems; still the same webhost too. Still stuck.
14 years 6 months ago #123515 by sozzled
14 years 6 months ago #123541 by LittleJohn
This is a long shot...
Do you know if your host got mod_security enabled?
You can try insert this rule in your '.htaccess' file and see if it helps. If it doesnt, do revert the changes asap!
<IfModule mod_security.c> SecFilterEngine Off SecFilterScanPOST Off </IfModule>
The following user(s) said Thank You: Bkoubs
14 years 6 months ago #123585 by Bkoubs
LittleJohn, thank you for being straight to the point and not pointing me around to forum posts that have too much information not pertaining to my problem! So yes I am assuming my host does have mod_security enabled and that added to the .htaccess file worked! Now my question is what are the side affects of adding this to the htaccess file? Decreased security?
