Question after upgrade, variables aren't translating
14 years 4 months ago #114046 by bjassoc
e.g. COM_KUNENA_STAT_TOTAL_USERS: 27 | COM_KUNENA_STAT_LATEST_MEMBERS: bmistriel
COM_KUNENA_STAT_USERLIST »
COM_KUNENA_STAT_MORE_ABOUT_STATS »
COM_KUNENA
it's a language problem - how to fix? It looked fine before the upgrade.
14 years 4 months ago - 14 years 4 months ago #114047 by sozzled
G'day, bjassoc, and welcome to Kunena.
What language are you trying to use? What version of Kunena are you trying to use? Upgrade or fresh installation ? What did you "upgrade" from? Did you read the upgrade/installation guide(s) and Read Me notes for the version of Kunena that we're discussing?
Last edit: 14 years 4 months ago by sozzled.
The following user(s) said Thank You: bjassoc
14 years 4 months ago #114048 by bjassoc
G'day to you. I updated to 1.7.1 from 1.5.x (don't remember the x!), then realized (after posting this) that I hadn't installed all the modules and extensions. So I did that.
Now the forum is still "offline for maintenance" - meaning there's still something I need to do? Or how do I get it back online so I can see if perhaps the problem got fixed?
I did read the instructions. do I need to install a Language pack? (Forum is in english.)
thank you for your help.
14 years 4 months ago #114050 by bjassoc
Reading the Notes more carefully, I see my Joomla is 1.5.20 (not 1.5.25) and my PHP is 5.2.17 (not 5.2.3).
Doesn't sound related to my problem, but perhaps?
14 years 4 months ago #114051 by sozzled
bjassoc wrote: Reading the Notes more carefully, I see my Joomla is 1.5.20 (not 1.5.25) and my PHP is 5.2.17 (not 5.2.3)
Both if of these are OK for your purposes (although it's better to update to J! 1.5.25. PHP 5.2.17 is a later version than PHP 5.2.3. :)
Your forum is offline for maintenance could mean that the installation failed part-way through and, if you're using English, that's what it sounds like to me. I would try to re-do the installation again. If necessary, the installation also gives you a way to go back to K 1.5.x (whatever was last installed).
*** Topic moved to more appropriate category ***
14 years 4 months ago #114052 by bjassoc
Sozzled, where did you move this topic???
I reinstalled as you suggested - and there was an error msg that I missed before: "Language Install: No core pack exists for the language :en-GB"
I see this has reported by others here, but haven't found the fix on this Forum.
