Question Moved my server to PS and kunena links are not working !
14 years 5 months ago - 14 years 5 months ago #112228 by camsarim
I just requested to move my site (was an on shared server) to a PS.
Kunena is crashing ! I tried to enable disable SEF from Joomla and Kunena, htaccess, created a new menu from kunena, tried everthing. Can't get the main page of Kunena, no links are working. Everything returns a 404 error.
Would uninstalling and reinstalling kunena help? Or how can I reset the htaccess?
Please help ! Don't know what to do.
Last edit: 14 years 5 months ago by camsarim.
The topic has been locked.
14 years 5 months ago - 14 years 5 months ago #112237 by sozzled
I've seen your configuration report posted elsewhere . You have different versions of Kunena and add-ons; you're not using a standard, default Kunena template; you've got legacy mode enabled and your Kunena menu had conflicting targets. You need to bring your software up-to-date, remove your dependence on legacy mode, try with the Blue Eagle template and fix up the menu and maybe then you will have the basis of an installation that allows your Kunena menu links to work properly.
Please read the FAQs page for further advice.
Last edit: 14 years 5 months ago by sozzled.
Time to create page: 0.236 seconds
