To get started please see
K 1.6 & K 1.7 Installation Guide
in our
Documentation Wiki
Important Upgrding K 1.7.0 -> K 1.7.2: Invalid argument supplied for foreach() in /home/site/public_html/administrator/modules/mod_menu
14 years 10 months ago #111306
by thepiston
Upgrding K 1.7.0 -> K 1.7.2: Invalid argument supplied for foreach() in /home/site/public_html/administrator/modules/mod_menu was created by thepiston
tried twice with same result:
Warning: in_array() [function.in-array]: Wrong datatype for second argument in /home/site/public_html/plugins/system/jdownloads/jdownloads.php on line 171
Warning: Invalid argument supplied for foreach() in /home/site/public_html/administrator/modules/mod_menu/tmpl/default_enabled.php on line 150
Warning: Invalid argument supplied for foreach() in /home/site/public_html/administrator/modules/mod_menu/helper.php on line 83
anyone else?
anyone else?
14 years 10 months ago #111307
by Matias
Replied by Matias on topic Re: errors upgrading from 1.7.0 to 1.7.1
Error is not in Kunena, it's in the JDownloads plugin. You also have some issue with your menu (you may want to check it).
14 years 10 months ago #111308
by thepiston
Replied by thepiston on topic Re: errors upgrading from 1.7.0 to 1.7.1
so you think it installed ok?
- snilloconator
- Premium Member
- aka snilly
14 years 10 months ago #111314
by snilloconator
Replied by snilloconator on topic Re: errors upgrading from 1.7.0 to 1.7.1
Disable the jdowloads plugin and see if you can access with no errors.
14 years 10 months ago #111315
by thepiston
there are no errors Isee using the forum in front or back. looks ok. i might try it just to see though. the jdownloads extension is beta.
14 years 8 months ago #117346
by thepiston
I just got same errors installing 1.7.2 over 1.7.1. I disabled the jDownloads plugin but still get same menu errors as you. Are you also using RT's Modulus template? Why would mod_menu be bad?
Time to create page: 0.235 seconds
