Important Upgrding K 1.7.0 -> K 1.7.2: Invalid argument supplied for foreach() in /home/site/public_html/administrator/modules/mod_menu
14 years 5 months ago #111306 by thepiston
tried twice with same result:
Warning: in_array() [function.in-array]: Wrong datatype for second argument in /home/site/public_html/plugins/system/jdownloads/jdownloads.php on line 171
Warning: Invalid argument supplied for foreach() in /home/site/public_html/administrator/modules/mod_menu/tmpl/default_enabled.php on line 150
Warning: Invalid argument supplied for foreach() in /home/site/public_html/administrator/modules/mod_menu/helper.php on line 83
anyone else?
14 years 5 months ago #111307 by Matias
Error is not in Kunena, it's in the JDownloads plugin. You also have some issue with your menu (you may want to check it).
14 years 5 months ago #111308 by thepiston
so you think it installed ok?
14 years 5 months ago #111314 by snilloconator
Disable the jdowloads plugin and see if you can access with no errors.
14 years 5 months ago #111315 by thepiston
there are no errors Isee using the forum in front or back. looks ok. i might try it just to see though. the jdownloads extension is beta.
14 years 3 months ago #117346 by thepiston
I just got same errors installing 1.7.2 over 1.7.1. I disabled the jDownloads plugin but still get same menu errors as you. Are you also using RT's Modulus template? Why would mod_menu be bad?
Time to create page: 0.267 seconds
