Question Failure load English-UK Langauge pack
15 years 2 months ago #107151 by rmesa4748
During installation final step a failure displayed regarding language English-UK failed. I checked the control panel found the following panel below:
Report Configuration Settings
* Error loading component: AlphaUserPoints, 1
* Error loading component: comprofiler, 1
* Error loading component: Community, 1
* Error loading component: uddeim, 1
Please advise.
Robert
15 years 2 months ago #107152 by rmesa4748
More info:
15 years 2 months ago #107672 by Matias
This has nothing to do with languages -- you have used JUpgrade, haven't you? I've fixed a few bugs into version 1.2.2 and one of the fixes are fixing this issue.
Joomla 1.6.0 is also very buggy, so you must have used very old version of it..
