Question ERROR: plg_jomsocial_kunenagroups: Kunena 1.7 (or later) is not installed on your system!!!
14 years 8 months ago #105698 by davidcrespo
In selfcode.org have installed Kunena 1.7 in joomla 1.5 with jomsocial 2.4, all features are working very well except the plugin plj_jomsocial_kunenagroups which has been activated through the Plugin Manager system in Joomla Administration, set to Yes for Core Application and 0 for Allow Jomsocial Categories - The rest remain as default as well- .
Perhaps you can give me some advice on how to fix the problem, maybe some configuration I'm missing?
Thanks!
Below is the report
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 50M
Joomla default template details : rt_tachyon_j15 | author: RocketTheme, LLC | version: 1.5.7 | creationdate: June 14, 2011
Third-party components: AlphaUserPoints 1.5.13 | Jomsocial 2.2.4
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | My Kunena Forum Menu 1.7.0 | My Kunena Forum Posts 1.7.0 | Kunena Groups 1.7.0
14 years 8 months ago #105715 by Matias
Your configuration report says that you're not installed Kunena 1.7.0. Maybe some of the files (namely administrator/components/com_kunena/api.php) were not updated because of wrong permissions or something?
14 years 8 months ago #105754 by davidcrespo
Thanks for your response. You were right! Have downloaded Kunena 1.7, did the upgrade and worked just fine! Sorry for the mistake!
Thanks!
Time to create page: 0.213 seconds
