Question Blank Page (Frontend and Backend after Login) after Upgrade to Kunena 1.6.5
14 years 8 months ago #104708 by zedian
Dear Kunena Community,
after upgrading from Kunena 1.6.4 to 1.6.5 today, front- and backend only show a blank page. I can access the backend login page but after loging in with the credentials it also shows a blank page. So, I cannot simply uninstall and/ or re-install Kunena. Every input would be appreciated because as blank as the pages is also my problem-solving on that issue.
Some information:
Joomla 1.5.23
Legacy Mode = 1
Technical Kunena Requirements met
uddeIM 2.4
Community Builder (last stable 1.5)
JoomDOC (last stable 2.2)
Projectfork
AkeebaBackup (last stable)
MyCommunity Template
Any input would be great...also just tell me if I forgot to list something.
Thx
z
14 years 8 months ago #104739 by xillibit
14 years 8 months ago #104792 by zedian
Thanks, the outcome is the following:
Adding ini_set('display_errors', 1); and error_reporting(E_ALL); and reloading:
Blank Page
Adding php_flag display_errors On
Blank Page
Check Kunena installation is ok
Cannot do because no backend access. However, in the database it shows still the old version number and not 1.6.5
Enable the debug mode
So far I got myself, I think for the rest I have to contact my provider.
1. However, is it possible to deactivate Kunena Component via Database to figure out if that solves the problem and at least I get access to the backend again?
2. Or is it possible to overwrite the new Kunena files with files from an older version which did not cause the problem yet?
best
z
14 years 8 months ago #104795 by xillibit
I don't recommend to uninstall Kunena manually, what are your php and mysql versions ?
Are-you using third party kunena tempaltes ?
Are-you using Joomla third party template ?
Are-you using plugins/modules for Kunena (if yes which versions) ?
Are-you using third party ACL component (Artofuser, ...) ?
The following user(s) said Thank You: zedian
14 years 8 months ago #104805 by Matias
Blank page issue comes most likely from a broken system plugin -- look at jos_plugins table and try to find and disable all Kunena related plugins.
14 years 8 months ago #104813 by zedian
@xillibit:
Server: Localhost via UNIX socket
Server version: 5.0.51a-24+lenny5
Apache/2.2.9 (Debian) DAV/2 SVN/1.5.1 PHP/5.2.14 mod_ssl/2.2.9 OpenSSL/0.9.8g
MySQL client version: 5.0.51a
PHP extension: mysql
No Third Party Kunena Template or Plugin/ Module for Kunena
MyCommunity Template from Joomlapolis for Joomla
The only thing connected with Kunena Forum was Community Builder 1.5 via GroupJive
@Matias:
Tried but did not work :/
Time to create page: 0.285 seconds
