Question problem with re-installetion
15 years 4 months ago #100922 by inbal
I installed the 1.6.4 successfully but, because I needed a version in Hebrew, I uninstalled it and tried to install the 1.6.2 (which is the most updated one I have translated). and the forum was not in Hebrew...
so I deleted the files from my FTP ( I think... it was late, not really sure what I did there :) )
and now I can't install either of the versions:
I get a :
Component Install: DB function reports no errors
Failed deleting install.script.php
Error installing component
I 've searched it in the internet but all I found is that it's a but of joomla 1.6 and that I have to delete the files manually, but I already deleted all of them ( unless one is hiding really really well)
Pleeeesae- any help?
thank you :)
Inbal
15 years 4 months ago #100923 by sozzled
G'day, inbal, and welcome to Kunena.
The lesson is a bit late now but you do not uninstall any Joomla extension by removing the files on the server without first using Joomla to uninistall the extension. I suppose, too, it's too late to ask you to go back to the site backup you made before you made any of these changes.
What version of Joomla are you using?
