Merged My Joomla template displaces Edit/Quote/Reply buttons
15 years 2 months ago - 15 years 2 months ago #99704 by rsa
Hi all,
Only recently installed Kunena but got a problem with the Edit/Reply/Quote toolbar. See attached image. Won't show properly. Can anyone help please?
My report below:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 20971520 | Max file upload: 5242880
Joomla default template details : hot_ecommerce | author: HotJoomlaTemplates.com | version: 1.0 | creationdate: October 2010
Last edit: 15 years 2 months ago by sozzled. Reason: Changed subject to improve relevance for search purposes
15 years 2 months ago - 15 years 2 months ago #99726 by sozzled
G'day, rsa, and welcome to Kunena
The issues are caused by your Joomla site template.
You need to add the following lines to the end of your Joomla site template CSS file:
#Kunena .kbuttoncomm span.quote { background-color: transparent; background-position: 0 -440px; font-style: normal; line-height: 14px; padding: 0; }
The following user(s) said Thank You: rsa
15 years 2 months ago #99741 by rsa
Excellent! Thank you so much.
Edited the layout.css file and all working now!
thanks again!
15 years 2 months ago #100810 by dobso
Replied by dobso on topic Problem page Kunena!
In the left bottom of Topic......
Can anyone help me?
Kunena 1.6.4
15 years 2 months ago - 15 years 2 months ago #100813 by sozzled
G'day, dobso, and welcome to Kunena.
We have solved this problem before, and I know exactly what is causing the problem. Your problem is caused by the template that you are using. If you searched the forum using the name of your Joomla template you will find the answer. I hope that helps.
I can't remember which emplate was involved last time, otherwise I would give you the answer immediately. Which Rockettheme template are you using?
15 years 2 months ago - 15 years 2 months ago #100815 by dobso
hot_cars
HOTJoomla Cars Template
I dont have Rockettheme
Last edit: 15 years 2 months ago by dobso.
Time to create page: 0.288 seconds
