Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question Changing Default Font Size in Editor
15 years 6 months ago #58934 by AndyInSpain
Hello all,
This should be an easy one to sort out. Where in the CSS, in the Kunena 1.6 Blue Eagle template, can I change the default font size for the text area when composing a new post (like I'm doing now)? It's a bit small.
Below is the config report. Any help would be much appreciated.
Kind regards and thanks for a fantastic product.
Andy.
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Kunena version detailled: Installed version: 1.6.0-RC1 | Build: 3173 | Version name: Kujadili | Kunena detailled configuration:
The topic has been locked.
15 years 6 months ago - 15 years 6 months ago #58937 by Cerberus
in kunena.forum.css ( you will need to reminimise this using refresh-sf.com/yui/ to make the kunena.forum-min.css file again )
#Kunena table#kpostmessage .ktxtarea { border:1px solid #BFC3C6; font-size:1.5em; <---- add this line ( 1em is default size ) height:200px; overflow:auto; }
I recommend make a custom template rather than modifing the default one so that when you upgrade your changes are not lost.
Last edit: 15 years 6 months ago by Cerberus.
15 years 6 months ago #58946 by AndyInSpain
Many thanks for your swift reply, Cerberus. It is much appreciated. I shall do exactly as you request.
Thanks very much and kind regards
Andy.
15 years 6 months ago #58966 by Cerberus
your welcome :) the thanks button is a wonderful thing ;)
The following user(s) said Thank You: AndyInSpain
15 years 6 months ago - 15 years 6 months ago #59078 by AndyInSpain
OK, all done, but can I be a pain and ask you which CSS section controls the font size for the Quick Reply box? It seems to be different from the compose/reply text areas.
Many thanks
Andy.
Last edit: 15 years 6 months ago by AndyInSpain.
15 years 6 months ago - 15 years 6 months ago #59085 by Cerberus
yes quick reply is a different css section.
#Kunena .kreply-form .inputbox { background:none repeat scroll 0 0 #FFFFFF; border:1px solid #999999; color:#000000; font-size:1.5em; <---- add this line ( default value is 1em ) margin:2px 0; }
Time to create page: 0.261 seconds
