- Thank you received: 5
Kunena 6.4.9 & Kunena 7.0.1 Released
The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question Changing Default Font Size in Editor
and I am editing files in com_kunena/template/default_ex which is set as default template
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 128M
board_title All About Recovery network board_offline 0 board_ofset 0 offline_message <h2>The Forum is currently offline for maintenance.</h2>
<div>Check back soon!</div>enablerss 1 enablepdf 1 threads_per_page 25 messages_per_page 10 messages_per_page_search 15 showhistory 1 historylimit 10 shownew 1 jmambot 0 disemoticons 0 template example showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 3600 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 75 maxsig 500 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 imageprocessor gd2 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 0 imageheight 800 imagewidth 800 imagesize 150 allowfileupload 0 allowfileregupload 0 filetypes zip,txt,doc,gz,tgz filesize 120 showranking 1 rankimages 1 avatar_src fb_profile pm_component userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 0 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 10 showpopsubjectstats 1 popsubjectcount 10 usernamechange 0 rules_infb 1 rules_cid 54 rules_link www.allaboutrecoverynetwork.com/terms help_infb 1 help_cid 59 help_link www.kunena.com/ showspoilertag 1 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type thread rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 fbdefaultpage categories default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 1 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 6 pollallowvoteone 1 pollenabled 1 poppollscount 10 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 0 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 100 thumbwidth 100 hideuserprofileinfo put_empty integration_access communitybuilder integration_login communitybuilder integration_avatar communitybuilder integration_profile communitybuilder integration_private uddeim integration_activity communitybuilder boxghostmessage 1 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankysoustats 1 popthankscount 10 mod_see_deleted 0 bbcode_img_secure text
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Enabled (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Enabled (Version : 2)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.0-RC2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed
Before suggesting how you can make a change to your current default template CSS, we recommend that users should not modify this template's CSS because, when you upgrade Kunena from RC2 to a later version, you will have to make all these changes again. It's a better idea to make your own template so that your changes won't be lost. Details on how to make your own template are currently a work-in-progress at the Wiki (see How to create a template for Kunena and K 1.6 Template both of which are unfinished and they'll be merged into another document, I expect).
The quick-and-dirty method is to edit the K 1.6 template CSS file (see Where is the CSS file? ), and minify that file and copy the minified file to that folder. Or you can use the clear text version and run Kunena in debug mode.
The change that you will probably want to make is this:
#Kunena .kreply-form .inputbox {
background:none repeat scroll 0 0 #FFFFFF;
border:1px solid #999999;
color:#000000;
font-size:1.5em;
margin:2px 0;
Experiment with different values until you find something that suits your purposes.
The best way to play with these things is to use Firebug for Firefox as recommended in Changing Template and its Colours - the Basics
Does this help?
Thank you!
jodin wrote: Awesome. You guys are doing a great job and are very helpful!!
Thank you!
Thats weird. Whats up with the scrollbar in my last post??
