Question Removing the whole top box, not just the menu tabs.
Why do I want this removed??? Well my actual forum is not visible to my users. I setup my menu links to display certain forum categories. With the tree nav setup they can click and actually view the index which show the whole forum. I don't want them to see that.
How can I fix this?
Check out My online community. Once you stop by you will be hooked. www.JameZtown.com
You know how to remove the menu tabs (actually, it's quite easy: simply unpublish the "Kunena Menu" module in Module Manager).
Removing the whole "top box" is also simple, too: see How can we remove whole profile box; we can only disable login box in K 1.6?
I added the 3 lines to the very end of the css.template
Did I do something wrong?
To remove those things, you also need to add these lines of CSS to your Joomla site template:
Add the following three lines to your Joomla template CSS file:
