- Thank you received: 7
Question attachments (add file) popup issue
as you can see in the picture attached, the yellow popup box for "allowed file extentions" is a bit short!
i searched in css files (thanks to FireBug!!!) and change the width property of "kfile-hide" class in both kunena.forum.css and kunena.forum-min.css files:
but it didnt work!
any ideas how to enlarge width of it?
Love Simplicty
read...... and learn........
My Joomla Test Site
The reason that the tip text exceeds the "popup" dimensions is because there are no breaking space characters. If there were breaking space characters, the text would wrap onto a new line.
i'm using JA_Purity which is one of joomla default templates!yuzef wrote: i think that was caused by your joomla theme. please try default joomla template and see your kunena forum again, is the problem persist ?
sozzled wrote: This took me a little while to find the answer. The size of the tip layer is defined in the Kunena template CSS file as
The solution is to add following lines to your Joomla site template CSS file:Code:.tool-tip { background: none repeat scroll 0 0 #FFFFCC; border: 1px solid #D4D5AA; float: left; max-width: 200px; padding: 5px; }... or some other value as as your choose.Code:.tool-tip { max-width: 300px; }
which css file exactly???
i searched all css file in joomla/components/com_kunena/template/default/css but there is no such css id...
Your Joomla site template CSS file ... don't change Kunena at all. Simple. Easy.nima.abbc wrote: which css file exactly???
