Solved Formatting Issue - Welcome User / Statistics Areas
15 years 6 months ago - 15 years 6 months ago #95015 by cv81
To summarize, my Kunena has been great but I can't for the love of me even figure out how to fix this. There are extra page breaks and unnecessary spacing.
See screenshot below of the two troublesome areas.
Joomla default template details : gk_sporter | author: Robert Gavick - GavickPro | version: 1.0.7 | creationdate: 30/09/2010
Third-party components: Jomsocial 2.2.1
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | My Kunena Forum Menu 1.6.2
Last edit: 15 years 6 months ago by cv81.
15 years 6 months ago #95103 by cv81
Also, I'd like to shrink my whole kunena tables down as a whole + font .. Is there a quick fix.. ? Here is the link for my forum for both challenges
www.gmgames.org/index.php?option=com_kun...t&catid=0&Itemid=125
Cheers
15 years 6 months ago - 15 years 6 months ago #95164 by sozzled
Do these problems of page-breaking occur when are not logged in? I looked at your site (using Firefox 4) and I could not see the issue you were trying to demonstrate with the images you posted.
Have you looked at the possibility that the problem(s) is/are caused by the site template that you are using? Have you investigated the problems with a web design tool like Firebug ? Firebug is the "quickest fix" that I know for issues like yours. ;)
Last edit: 15 years 6 months ago by sozzled.
The following user(s) said Thank You: cv81
15 years 6 months ago - 15 years 6 months ago #95186 by cv81
Thank you for the prompt reply. Ironically it is firefox 4 I am using myself. Ive been trying everything with FireBug to try and find how to make the left align and right align work on the same level. I can't seem to find the alignment, width % or anything by trial and error.
I just tried IE and I get the same issue...
-- The statistics breaks still happens logged in or not. The welcome area I'm not too concerned and you didn't see because you weren't registered.
It's most definitely my template because nobody else has this issue.. I've googled my same question and I got this hyperlink again! :)
This is with IE7-8, as well
Any help on the css itself and which alignment portion would be so greatly appreciated.
15 years 6 months ago #95187 by sozzled
Try this:
Edit your file www.gmgames.org/templates/gk_sporter/css/template.css at around line 28 where it says
ul { clear: both; list-style: none outside none; }
... and change it to this
ul { // clear: both; list-style: none outside none; }
15 years 6 months ago #95188 by cv81
Dude! I love you. (In a techy kind of way) haha.
That was it, it was way further up to the template css and not just kunena. Rock on! Thanks again
Time to create page: 0.155 seconds
